#ZERO
Beach Bum
- Florida - U.S.A.
You need a canopy and a gas pedal for that amphibious golf cart.
mfg:
You need a canopy and a gas pedal for that amphibious golf cart.mfg:
Just my opinion but I had a small pin 750 in mine last time it ran, I used the stock 650 exhaust, truefully there was not a lot of difference in power, it pulled out of turns a little better, that was about it. Looking back I think that hose you are blocking off really does make a lot of difference, especially since the exhaust pipe is already shorter. You are looking at about a 30 minute job to drill and tap that flange for a fitting, its up to you but I know what I would do knowing what I know now.
Here is an idea put a shutoff valve in the line that way you can play with the water flow and fine tune it.
That's a good idea.
You think a three way stop-cock type setup would work in this location?
Bam! What u think Terry? Well see how it works. It's already a restrictor since the valve ID is 1/4". I'll try it wide open and tune as I go. I came across the ones that have the hose clamps built in, that r made for PEX. I decided on this one since I can be sure it isn't gonna get damaged/melted being next to the stinger.
Glad to finally see this come together. I finally have mine back together and she will be going on the maiden voyage this weekend....hopefully. I rebuilt and installed the 650 with a coffman pipe. To restrict the water to the stinger, I used a VCR connection. I drilled out a few blank VCR gaskets to different sized to restrict flow. When I need to change the flow, just open up the fittings and swap in a new gasket with a different diameter hole. My buddy did this on his superjet and it worked great.
