- HOLLAND MA.
2010 crf 250 has been doing me right, new fuel inj is very nice, no more adj nor cleanings..the throttle is either on or off due to tps sensor but motor puts down some serious power with no bog anywere. The 2010 went backwards with the front end as far as were its located..way to close to bike. Cuts into berms early aswell as out. Applied makes a custom clamp set for this, its a 24mm offset to get the front end back were its suppose to be. They are on order for my bike should be here buy the end of the week..these are a must! If ur under 200lbs get the factoryconnection rear link wich levels the bike out and aids the front aswell. FC worked the suspension with springs aswell, bike was night and day in controlability. I made the carbon ride plate with case saver. FMF megabomb full tie setup smoothed power out. I didnt notice a power increase but weighs half the stock system.
