That pole is way too long, you will find out once you ride it, with these skis you have to get your weight way up front or they ride nose high and you will never be able to recover from landings. I will post a pic of where my steering ended up at for reference. Also I am not sure what you did on the rear exhaust but basically the whole stock setup needs to go and be replaced with a 2" tube straight out the back.
