yes it will work. best cases are the 62t, a couple hunderd dollars. x cases can be found for 100 or less. you will need a 61x cylinder, pistons, head, intake, and the carb will need to be rejetted. port the pipe like stated above. just use a 701 exhaust gasket to match the pipe up. put the gasket on the pipe lined up the the bolt holes. mark the pipe where the gasket does not match and dremel out. shouldn't be a lot to have to take out.
