retroicon
XX-xx-XX-xx-XX
Yes, pressure... when I open the tank, you can hear the air escaping.
So let's dig deeper here. If I'd primed the motor with a bunch of fuel, and then hit start, and it immediately revved up to almost wide open, even with the butterflies on the carbs barely open, could that be a result of there being fuel in the motor that got the motor fired, and because the motor didn't get more fuel from the carbs, it went lean causing the high revs?
-G
-G
