I have a sheet of molded diamond Hydroturf for the grab rail on my PJS VHP 7000 Viper and after reading the posts here, I still have a question or two:
After applying the turf to the top surface of the grab rail and then down the sides (with heat) do I just cut it off along the bottom edge or do I try to wrap it around and back under? I'm thinking it would be hard to do but the alternative of having a glue edge along the bottom may peel easily.
I'm planning to start with a piece of turf at the front to get the nose bushing area right and then do two side pieces. Can you guys successfully match the diamond pattern where the pieces join?
One more thing...Do you glue the entire piece at the same time or should I just get the top surface glued down, then apply the contact cement to the sides next, etc. so I don't have to worry about sticking it down wrong when stretching it to fit?
