Super Jet How to Stock Throttle on UMI Bars
djkorn1
kidkornfilms
Cleveland Ohio
How do you attach a stock Throttle onto aftermarket bars....
There is only one screw and it just spins in the hole in my UMI bars. Should I drill all the way through and just put a nut on the end? :chairshot:
Ohio
Korny I think the hole on the bars is for a pin on the stock throttle to sit in. Then the throttle lever just tightens around the bars.
Tuscaloosa, AL
you place the finger throttle exactly where you want it and take a drill bit that is a tad smaller than the screw and drill a hole. Then use the screw to self tap itself into the bars.
The hole that is there is for the start stop box, there is a small tit that will sit in there to keep the module from rotating.
