how to disassemble white start/stop connector
WaveDemon
Not Dead - Notable Member
Hell, Florida
I know I've done this before. it can be done!
the wires have pulled out of the female end of the white start stop connector. I can't seem to get the pins to come out. I pulled the little round rubber grommits and I'm stuck there.
Is there a tab that clips the pins in? don't the pins pull out the same direction the grommits pull out?
Boris
The Good Old Days
Yep, there's a tab on the pin that you need to push down on. It's on the opposite side to where the wire goes in.
Once you mush it down pull the wire out with the pin.
Shonuff
I've got the glow
Memphis
There's a small barb at the bottom of the metal tip that has to be pressed in before you can pull it out.
EDIT:
I'm thinking of Kawi start/stop.
WaveDemon
Hell, Florida
is this the way you move the tab?
mine is kinda buggered up inside. these might get cut off tonight if it doesn't work out soon.
Boris
The Good Old Days
Now that you got it all worked out,
anyone know where or who sells the pins ?
I have a few start/stop switches with corroded pins that I would love to repair.
