- Southeast, MI
I was hoping for some assistance in determining the root cause of the failure of this motor.
Background
I purchased my ski back in 2017 (95 SJ) with a motor that was a little on the low side for compression, about 135psi in each hole. This motor was solid and ran for about 5 or 6 years until needle bearing failure destroyed the engine beyond repair. I decided to purchase a rebuilt motor from a seemingly reputable jet ski shop in Michigan, stand ups seemed to be the guys specialty he had about 40 personally owned. I mention the old motor because after cleaning i reused the intake system however, i did reset the carb to what i believe were factory settings and rebuilt the reeds for the new motor. When i got the new motor it initially did not have compression in the front cylinder (~30 front / 155 rear) took it back the the shop and the dude corrected the issue. I didn't ask at the time what the problem was. Afterwards the motor appeared to run fine, i went out maybe 3 or 4 times no apparent issues. The next time i took it out it would not start at the ramp, after checking compression it was back to (~30 front / 155 rear). Afterwards the ski sat for about 2 years.
Failure
I finally decided to get the ski going again because i purchased a house on lake erie
. Today i checked compression again 30/155 same as two years ago so decided to disassemble thinking maybe there was a ring issue with the front cylinder. The engine had about 3-4hrs, cooling appeared OK from what i remember (no change in pisser volume after new motor installed), oil content 45-50:1, premium unleaded stabilized (no rec gas), plugs still looked brand new (only had a few hrs on them)
Rear Cylinder (155psi)
- a lot of carbon build up
- head gasket showing blow by
- seems to have experienced some heat but no failure
Front Cylinder (30psi)
- Rings welded to the piston
- a lot of scoring and contact/rub with cylinder wall
Basically I'm trying to understand root cause, my initial thought is a cold seize I'm a little hesitant though because of how much more damage was experienced by the front cylinder (my thought is damage would be more uniform). I'm undecided if i will rebuild this or purchase a new one. If the root cause possibly exists somewhere outside of the motor (carb/supporting systems) i'd like to understand that out so the issue doesn't repeat, skiing season is short in Michigan and i hope to not be rebuilding again in the middle of summer. Thanks in advance for the help/suggestions!
Background
Failure
