well like i said, the 1211 will for sure help seal it up because it is a setting compound. but it is a pain to remove and clean after. the hylomar or permatex aviation does not have the sealing ablilities as the 1211 but..... it will help seal and after 3 years of running the motor when you break it down again, the gaskets will not be stuck to the cylinder or cases. you will be able to peel them off, clean the surfaces with acetone and reinstall you new gaskets. I use it for this reason and not the sealing reasons. i have put to many gouges with the razor and worn out my finger nails scraping the 1211/gasket off. same with the oring heads, orings are supposed to be reuseable but if you 1211 them in, you will rip them removing the head, WTF right? so why use 1211? beats me, i never use it, i threw it out and have never found a need for it again once i found hylomar or the permatex aviation which is available in canada and is the same as the hylomar. just my thoughts.
