factory pipe.
Will this factory blaster exhaust fir an x2, or will this not fit aswell as the limited?? or iss this a limited???
Also when people run factory pipes do you still run a waterbox up front?
yes it will work. that is the factory mod pipe. you will still need to run a waterbox, way to much noise without. limited pipe works well too. thier is a lot of info on this topic on this site. both pipes have been run in x2s. dont forget to rejet your carbs!!!
