- New Hampshire
62t/61x
Ada head 165psi compression
R&D intake manifold, intake spacer and novi 44 carbs (I think)
Factory a pipe (2 water screws)
Lightened zero flywheel
unported cylinder.
It runs ok but
Bogs or even will shut off with an immediate pin.
115 pilot jet 120 main jet gold spring and 1.5 needle and seat.
Top water screw shut bottom open 3/4.
Low speed out one Turn and high speed out 1/4 turn.
It is rideable but after 500 feet of wide open it will Gurgle
also...
I'm waist deep with it running and pin it it will shut off also. I feel the jetting is way off. I am running 93 pump @ 40:1 and am right around 500 feet sea level. I feel there is more untapped power left in this. Also has a sinle remote
Fuel pump setup. Thank you if you can provide any base line jetting advice. The prop is unknown pitch but it
Is a skat trac.
If anyone has any similar setups could you share?
Thank You
unported cylinder.
It runs ok but
also...
Is a skat trac.
Thank You
