- Rochester, NY
Ok, I'm getting antsy to start working on the skis as spring is around the corner here...can anyone help me understand what, if any, carb tuning I'd expect to have to do if I:
- bore the b-pipe / manifold diameter out to the "stock" diameter (46mm I think it should be? mine is smaller than "normal", it is a really old one).
- go from stock reeds to vforce 3's
- install the R&D angled reed spacer
Its a '98 RN with stock dual 38's, Pro-tec Rec head (180psi), MSD cdi, ltd chamber. Tuning is what I'd consider perfect right now. Prop is a 5mm-cut C-75 magnum swirl, 13/17 IIRC.
Also, is there any compelling reason to swap out the Pro-tec rec head for an ADA girdled head w/ 35cc domes? Should be the same compression, and I don't think I need to be as concerned about cylinder cracking as the 61x guys, but for some reason I wanna do it...
