Dasa 1200 5 port impeller pitch
NC
I was running a 14/21 lb/tb in an XI hull with 155 maxx pump with JSN1200, 760 zeel total loss, pfp wet, and full spec 49’s.
Not the same setup but relatively close. Just sharing in case that helps you get close with prop pitch.
I still have that prop if you are interested. Prop only has about 12-15 hours on it.
I was running a 14/21 lb/tb XI hull with 155 maxx pump with JSN1200, 760 zeel total loss, pfp wet, and full spec 49’s.
I think your Jsn is a good amount more powerful than my old 5port. But it gives me something to go by
