300/440/550 Crankshaft bearings
Hey all!
I've torn down my js550 for a rebuild... Got down to the crank and noticed that the crank bearings have an outer O-ring around them.
What do they do?? Is there any point to them? What would happen if they were replaced with bearings without the ring?
WFO Speedracer
Alabama
The orings keep the bearings locked in place in the crankcase, you can use regular bearings and put a thin pink film of red loctite on the bearings to hold them in position in the cases
