Cold Start Problem.
Layne
Addicted.
Springfield, MO
So got this Blaster not too long ago, forget what year but it has the 61x in it.
Anyways, its been a real pain to start it. Fuel is flowing, spark is good, cylinders are wet when I pull the plugs. Crank crank crank ... nothing. Hit the primer ... nothing.
Finally I think it might be flooding, turn down the low speed and resort to throwing a spray of starter fluid it (yeah I know bad, it was my last resort) and brap started right up. Turned it off, waited a couple hours, hit the starter and again less than a second of cranking and its back up, absolutely no problems, ran it on the water and it was a beast absolutely no problems.
Fast forward a couple days and its doing the same thing. WTF I thought it was just because it hadn't been ran all winter.
So I'm left scratching my head. Maybe some old gas?
Layne
Addicted.
Springfield, MO
Hmm well ill probably invest into a legitimate compression tester. All I was using was the rubber ended hope it seals one.
But on a 10 year old worn engine would 10 to 15 psi off of new be detrimental to a 150 psi engine? On the other blaster I was getting the same readings from but it starts on first crank almost everytime even after a week or so.
