- florida
hey guys im currently in the process for working out a deal on a carbon foot rocket, and while im waiting on that im trying to get togther a parts list so i can start purchasing parts for the build and well since i wont be having a complete doner ski, im needing some help with the list to make sure im not forgetting anything seeing as this is my first a/m build.
so heres what i got so far picked out, CHECK=purchased
2013 carbon foot-rocket CHECK
http://www.x-h2o.com/index.php?threads/full-carbon-foot-rocket-w-extras-6-500.167636/
rrp pole
http://www.thrustinnovations.com/handle-pole-c-32_30/rrp-billet-adjustable-handlepole-p-156.html
jetmaniacs freestyle ported 718 (blue head/black case) CHECK
http://www.x-h2o.com/index.php?threads/jetmaniac-62t-61x-freestyle-ported-motor-1725.77233/
solas 144 mag complete (potentially using a waveventure pump)
http://www.x-h2o.com/index.php?threads/solas-mag-pump-144mm-12vane-ss-for-yamaha-475.108950/
Impeller (the waveventure impeller till budget allows proper one)
need suggestions on pitch and stuff with this motor/pump combo.
jstl ign. w/ jetknetics lightened flywheel (stock one for now)
http://www.x-h2o.com/index.php?thre...l-ignition-module-with-a-touch-of-ocd.170521/
imitedslip7 3.3g tank CHECK
http://www.x-h2o.com/index.php?threads/5-gallon-tanks-for-pfp-or-b-pipe.146313/
engine mounts CHECK
http://www.x-h2o.com/index.php?threads/motor-mount-options-from-jetmaniac.138930/
xscream adj. sterring system CHECK
http://www.teamxscream.com/products...ucts_id=6567&zenid=km2852tc7d3qquj4m56flp3nh4
oem midshaft/housing
http://www.x-h2o.com/index.php?threads/midshaft-talk-building-rebuilding-sn-vs-rn-etc.105232/
oem 144mm wear ring (waveventure if possible)
http://www.x-h2o.com/index.php?thre...ar-rings-pump-shoe-intake-grate-parts.142220/
Xmetal Trim possibly thrust trim (have not decided yet)
http://www.x-h2o.com/index.php?threads/trim-systems-from-jetmaniac-thrust-and-xmetal.141581/
Steering/throttle cables
http://www.x-h2o.com/index.php?thre...perjet-waveblaster-fx1-kawasaki-cables.87804/
Intake/carbs CHECK
built and assembled by jm for the 718 with dual 38s
billet flywheel cover (blue) (stock for now)
http://www.x-h2o.com/index.php?threads/sb-products-billet-flywheel-covers.128587/
oem starter/wires (from waveventure for now)
http://www.x-h2o.com/index.php?thre...el-stator-start-stop-solenoid-cdi-msd.146781/
start/stop switch (if usable from wave venture)
throttle lever CHECK
http://www.thrustinnovations.com/th...-innovations-billet-throttle-lever-p-907.html
factory pipe CHECK
http://www.thrustinnovations.com/exhaust-c-22_23/factory-b-pipe-mod-superjet-p-43.html
xscream waterbox (if i dont choose the tnt) CHECK (went with oem sj box for now)
http://www.x-h2o.com/index.php?thre...issers-hoses-waterline-parts-fittings.101341/
grips/locking rings CHECK
http://www.thrustinnovations.com/grips-c-32_37/odi-grips-rogue-p-196.html
Battery
http://www.thrustinnovations.com/battery-c-18_19/deka-etx-12-agm-battey-p-1220.html
Fuel line/waterlines CHECK
bought locally
Rubber straps
http://www.x-h2o.com/index.php?thre...erbox-battery-misc-straps.61807/#post-1023535
Hood latch/ratchet and hood hooks
http://www.x-h2o.com/index.php?thre...d-strap-kit-35-hood-hooks-hood-latches.69533/
i know im missing alot of stuff but im still looking/trying to figure out what i want so feel free to comment suggestions on parts below ive been out of the sport for about 2 years now so im sure im forgetting alot of little stuff. this is also my personal list that im using to keep track of everything aswell.
rrp pole
engine mounts CHECK
Intake/carbs CHECK
factory pipe CHECK
Battery
bought locally
Rubber straps
