- grand island new york
does the 1100 rule have 1 inch line or is it 3/4?????
I have a brand new in box Rulemate 750 for sale. It uses 3/4 inch line.
$65.00 shipped anywhere in the USA. Here is a link with specs:
http://www.rule-industries.com/products/pumps/bilge_pumps/rule_700750/iid_239/index.htm
what do you guys run on your skis for bilges single 500gph or dual 500's?whats the better way to go wanna start ordering some goodies.
Duckbills are far from bulletproof. They dry out, crack, leak even if you have the tiniest peice of debris in them(sand, for instance) and only work while you are moving. I'd run a bilge as a back up for sure. $10.00 Atwood 500GPH, a hose, an outlet and a switch, cheap insurance, 10 minutes to install.
where do you run the piping from the bilge to out of the hull? I can't find a bilge in my engine compartment or a hole in the outer hull where a hose would come out for a bilge system.
