Bed plates for aftermarket hull, aluminum or stainless?
demolition_x
Not After Fame & Fortune
What would you use? Hull originally had aluminum and salt water got between the carbon and aluminum there and corroded everything and caused de-lamination.
so i was thinking of using stainless bar stock in its place, any reason why i shouldn't?
snowxr
V watch your daughters V
Waterford, MI
The stainless will weigh a lot more, and will be diffucult to drill and tap the mounting holes in. Stainless does corrode, so it may not be a better choice. Use aluminum, and wrap them in a layer of fiberglass to prevent some of the carbon/aluminum reaction.
