Bed plate lengths
88kawi5fiddy
pew pew lazers!
So Utah
Just dropped a motor in and the coupler length very short, as in the coupler teeth do not go all the way together. im pretty sure midshaft is out of a 94 sn.
are there different length bedplates that i might have screwed up since i have sets from various yamaha 700 and 650 motors?
What hull did you put the motor and shaft in? In a Superjet if you install mounts you should push them as far back as you can before you bolt them down. Check your mounts
