Recently chasing a "Miss" and "Stumble" above 2/3 Throttle. Thinking it was Electrical, ohmed Components Cold and Hot, swapped Spark Plugs, CDI and Ignition Coil.
Still rode the same, until the Engine died on me in the middle of the Lake. The Engine would start and immediately die. Primed the Engine and traveled 20 feet or so every time. A few more Fuel Squirts with the Primer and I made it to Shore without having to swim it in.
Ohmed all the Electrical Components again while still warm (have Bullet Connectors 'tween Ebox and Stator). All tested okay.
Then I decided to swap the Fuel Filter even though it was new this Season and looking from above, the Filter seemed clean, When I removed the Filter, I noticed a bunch of junk accumulating on the Bottom of the Filter. Dirty gas from the Gas Station Pump!
Because the Primer Tap was on a separate dead-end Fuel Line (not connected to Carbs), Fuel was flow-primed into the Carbs and supplied enough Fuel for very short runs. With a Choke, this would not have worked as the only Fuel Supply Line to the Carbs was blocked by a clogged Filter. The Primer saved the Day.
