jetski9010
Team RTYD
- Lancaster PA
I was talking to robert at www.jetskimechanic.com the other day and he was in the process of putting together a budget freestyle motor package for the 701 motor. Here is what he has come up with so far.
"Well I worked on the Yamaha Freestyle motor first and that price is $2095.00 for a Low end Power Grunt Freestyle Build!!! You send in either a 61X or 62T motor and we will do the following: Bore the cylinders to the 82.5 0r 83mm big bore, Freestyle porting to the cylinder, Freestyle case porting and stuffing, Modify the stock head for race or pump gas, 2-Wiseco Big bore pistons, Complete gasket and seal kit, Rebuild and true and weld crankshaft, complete assemble of the motor and pressure test for leak down! If you want to up-grade to ADA Gridle head add $250.00, Add carbon fiber reeds $119.95, RIVA intake spacer add $59.95. You can always email me to discuss the possibility!"
I think this is a good option for some people because it includes the crank rebuilding which a lot of people work up a $3000 motor and then forget they are also going to need a new crank because theirs is 10 years old. Also nice because you just send him you whole motor and he sends you back a complete producted pressured checked and ready to go. Just wanted to put this out there for anyone looking into motor options.
