SXIPro
JM781 Big Bore
- Here on the 'X' mostly
I've now broken my second Attwood pump 'basket' that I had epoxied to my hull. Do I need to go the bracket route or is there another way?
How are you breaking them? I've been using the same two for 2.5 years now. Is something hitting the bases or the pumps?
Sent from my DROIDX using Tapatalk
You are not alone, I went thru 4 of those baskets last year alone. I had a slow fuel leak that would push fuel out of my tank when the ski sat for extended periods of time and the fuel in my hull softened up the plastic basket and the 5200 holding them to my hull and contorted them beyond use. The other 2 broke cause my pop rivets were too close to the edges and cracked the base when i installed them to the new Blowsion bracket.
I emailed Attwood and they shipped me 5 brand new baskets, free of charge. I'll PM you the guys name and email if you'd like.
Zip tie the basket to the pump so there is more holding it together than just those two tabs.
were your attwood pumps the new or old style? New new style baskets are almost bullit proof.
