Adjustments needed for premix?
smokeysevin
one man with a couch
Houston
I got my 750 started the other day and want to make sure I don't blow it up when I take the ski out for the first time. The motor is stock except for a pjs 650 pipe, purple doo waterbox, and rear exhaust.
Is there anything special required for running premix through the cdk2 carbs?
Do I need to run a restrictor in the return line?
What premix ratio should I use during break in and then during normal run?
Thanks,
Sean
dfw
If its a single carb model I would raise the pilot jet up to an 80 and the main up to a 150. Then power tune the top screw.
Mike W
Infidel
North Florida
Bump, planning to take the ski out this weekend.
Anything in particular to look for during break in?
Sean
Not a jetting guru but once you get that right, just run your mix at 32:1 for the first tank. Don’t go over 1/2 throttle and don’t hold your throttle at one speed for a long time. Just very your speed. Second tank, 50:1 or 40:1 (whatever you prefer), same thing but 1/2-3/4 throttle. Third tank, ride as normal. This is how I brake-in a motor. Everyone has their own method.
