ADA girdled kit - for RIVA girdled head
DCRocks
Wavejunkies
Washington DC
Does anyone know if the ADA girdled kit (the girdle bolts) will work on the RIVA girdled head?
The girdled bolts for my RIVA head are stripped out, and RIVA no longer sells them.
#ZERO
Beach Bum
Florida - U.S.A.
The girdled size going into the case is M10X1.25 and the allen bolts are M10X1.50 thread size.
The allen bolts holding the head to the cylinder are M8X1.25
DCRocks
Wavejunkies
Washington DC
which riva head do you have?
The one in the attached pic.
RIVA does not list it anymore, but it used to be on this page
The top partially threaded allen bolts that run through the top of the head to the lower bolts that thread into the case are fine, it is the 6 bolts that hold the cyl to the case with what looks like long nuts on the top half of them that the top bolts thread into, that are the issue.
If the ADA kit worked, I would be replacing these 6 lower bolts and the 6 upper bolts, with the ones from the ADA kit.
BROSS
The future right here
Lake Norman, NC
Not unless you are going to drill the head to accept a 10mm stud, the riva head uses a 8mm stud, just sold a head with girdle kit is how I know. I also have a 1200 non pv riva head on a ski and its the same way.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
that looks like the greater yamaha/cool head thing Ive got.
I think he said it above, the holes are too small for the ada studs to go thru.
I dont really see why you couldnt simply drill them out the additional 2mm though.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
I mocked mine up tonight, on my head ( that looks like yours) the holes are already large enough to accomodate the ADA studs.
BUT, I think the thickness of the head might be a problem, its 3/8" or so thicker, so the stud length is reduced by that amount, it might still be enough to work though
