650 sx wiring question???????
Recently purchased a 94 750sx and a 89 650sx but the 89 was used for parts so it was in a few pieces. I just put it all back together but i can't figure out the wiring set up for the starter and battery. I found a ground cable lying in the engine compartment not hooked up to anything. Does this ground the battery to the starter? Also there is a ground coming off of the starter, does that go to the battery too?
Thanks in advance...
Vumad
Super Hero, with a cape!
St. Pete, FL
I have a '87 SX. I'll take a few pics for you when I'm done eating these bad ass pork chops my mom made. :nana:
Um, I don't know what that electornics box is called, but iirc, the wires from the batter go to the box, and then to the starter. Pics in a few.
Vumad
St. Pete, FL
Neg. goes from neg terminal to inside bolt on starter.
Pos goes from pos terminal to bottom middle bolt on the box, then from the upper outer bolt on the box to the outer bolt on the starter.
Little wires from the battery are for the bildge.
Thanks guys, i think i was just confused because i had an extra ground wire lying in there but that must have been from the old starter that was taken out of the ski. Hopefully i can get it fired tomorrow.
Vumad
St. Pete, FL
Hey, I was just out front working on the truck with a shop light. Get your ass out there and get that beast started! (Beast? More like a crippled kitten)
