- LHP
So i replaced the starter solenoid after troubleshooting for ever and ski still has trouble turning over.
So i have a couple of ?
First of, I tried jumper cables to an engine bolt from the negative and still has trouble turning it over. That rules out my cables and it would mean my starter is going, correct?
Second, if my starter is at fault, in order to get to the stater, i have to remove the exhaust pipe/manifold, correct? If so, do i need to torque the screws down on the exhaust manifold after i am finished?
Forgot to add, the ground/neg cable heats up real bad when trying to start it. A lil bit of smoke did come off it at one point. Could that be the problem?
If i do have to replace my starter, is it hard to do with medium mechanical skills and some tools? Any tips appreciated!
Thanks!
Dave:friday:
Thanks!
Dave:friday:
