Super Jet 61x flywheel and stator in a 62t case
JetManiac
Stoked
Vendor Account
orlando
Hi guys , I'm more of a Kawasaki man
Can I run a 61x flywheel and stator in my 62t case , running a 62t ebox ?
what is difference ? Thanks
Yes, the stator mounting area and crank snout on 6m6(650), 61x(701), 62t(701) cases are all the same. The engine is fine with either setup as long as flywheel and stator are matched. However, you should consider either msd enhancer or a 61x cdi to match the stator timing.
