* Lowered price to $17k AND will include the Big FOOT beach Kart with both sets of wheels/tires and includes a shop stand for the Ski.
Ever since son started racing Karts I haven’t had a chance to ride or do anything. We need a few motors and some extra frames, so selling my Superfreak. This was labor of love, as the pictures and parts list will show.
It literally has 1 tank total on it - it’s as new, fresh, and ready.
Kept the OG top paint (had a poll on here) and it’s in great shape, but re-finished the bottom, so it’s as new (not one scratch).
Turf is new.
Titled as a 2021 Special construction AND registered in the PIA state of California!! Clean title in hand, valid registration.
TEM built full Carbon hull, New stainless water lines (see some of my posts)
Pink foam board in tray
New Fire power battery
New Thrust nozzle / trim
New Solas 148 mag
New 10/16 Skat Swirl Prop
New OEM driveshaft
New carbon ride plate (older spare included)
New JD intake grate
New Paul Lehr built TPE 964 motor, pump gas (180/180)
New 46 Mikuni Carbs
New V force3 Reeds
New Titanium bolts/studs nuts for intake, cylinder, head, and exhaust
New electronics (New OCD surf armor coil and plug wires, new rectifier, new starter solenoid, etc)
New Zeal programmed by Paul, 2 different programs - surf and flat water
New Carbon B-pipe chamber (will include a brand new aluminum chamber)
New B-Pipe - Manifold and head pipe have a Cerakote coating
New X-metal scupper (has internal block off cap for surf)
New ez hull drains
New custom carbon exhaust tube
Bedplates, intake, front cover also have a Cerakote coating
New Fuel tank
New OEM motor mounts
New Motor mount bolts
New OEM starter
New OEM starter Bendix
JM re-built stator
JM or X-metal water box (can’t remember)
New RRP steering
New RRP bars
New RRP knee saver
New Blowsion levers
New OEM start stop switch and wiring
New OCD bilge pump wiring w/500gph pump
New SS mounted bilge switch
New steering cable
New throttle cable
New OEM midshaft housing and shaft
New Couplers (can’t remember which)
New OEM Coupler cover
New Custom carbon fuel pump bracket
New Mikuni external fuel pump
New pole breather tubes
New Pinch bolts with Spring perch
New Pole spring (yes, it’s has both pinch bolts for tight pole, or spring for the older riders like me)
New Thrust hood keeper
New thrust hood hooks (adjustable)
PP FFH
New Cover
100% new stainless bolts, washers, nuts (other than titanium ones mentioned)
New OEM fuel lines
New water hoses
New Jet works flow valve
New Spare Top End kit set-up by Paul
New… everything, even bolts (100% stainless)
Will include some spare parts for right offer (starter, solenoids, electronics, etc… ) as I’m getting out.
Also INCLUDES a big foot beach cart with little used and both surf as well as treaded tires that all hold air. AND will include a shop stand.
Located in NorCal. I don’t have the means, methods, or time to crate/ship, so if you want it, arrange to get it or send someone.
Price… $17,000
If you made it this far, thank you for looking.
Sent from my iPad using Tapatalk
Turf is new.
New Solas 148 mag
New OEM driveshaft
New JD intake grate
New 46 Mikuni Carbs
New V force3 Reeds
New ez hull drains
New Fuel tank
New OEM starter
JM re-built stator
New RRP steering
New RRP bars
New RRP knee saver
New Blowsion levers
New steering cable
New throttle cable
PP FFH
New Cover
New OEM fuel lines
New water hoses
Price… $17,000
