jkirkland
jkirkland
- inverness florida
Just picked up a 300sx that I am putting an 800 ported motor in. Looking for suggestions. I stripped everything off the ski and it weighed 89 pounds. Just the hull, no hood, no pole, no pump. Just the bare hull. Anyhow today I put a 550 sx pump in it with a 750 sxi driveshaft and thru hull bearing. Started fabbing up some mounts and have the motor set up in place. Trying to figure out what pipe to use. I have lots to chose from. I tried fitting a factory pipe in it but it is real tight to the gas tank and a little close to the side of the ski. It fits but not real good a couple of places that could rub. I also have a R and D pipe for a sxi that is a little more compact and seems to fit better. What do you guys think of using this pipe? I know the factory is the way to go but the R and D looks more suited for room. Also trying to figure out a water box I think if i stand up a coffman that came out of my 550 sx it will work or maybe a stock amuminum one out of a 750 sx any ideas on this? Will try to post some pictures Thanks for any help--Jason--
