2014 airblair fixed steer ( fixy)
-701 61x/62t bored out 1mm with new pistons and top end
-Head has clean up porting done by the machine shop it was bored at.
-All the transfer ports were matched in height and cleaned up of castings.
-New crank seals and gaskets.
62t stock ignition
-dual 38carbs with reed spacer plate stock reeds
- stock exhaust
- unknown waterbox 2" inlet 2" outlet
- 3 Blowsion billit pissers
- blowsion finger throttle
-144mm pump( can fit a 155 pump with a b2 pump shoe)
-Set up for dual cooling.
-Rear exit exhaust/drain
- new turf with 3/4 inch foam in the center and where the knees go and tapers down to 1/4 under the foot holds and front foot hold.
asking 5500.
I have owned this hull for about 3 years I have had multiple motor builds in it I have taken it with me on a few moves across the country and I still continue to ride it today It's a great ski to learn on and get into an aftermarket hull made by someone who supports there hull brand. Trailer is included in the sale also open to shipping.
Also, have titles so you can register them both ( located in Houston tx 77091 ) please direct message me or text @ 3528050912
62t stock ignition
- stock exhaust
asking 5500.
