- Rentz, GA
2011 Trinity Matrix Pro -2"
(Original Build Thread) https://www.x-h2o.com/threads/boyer...-ss865-144mm-setback-mag.133641/#post-1471571
Hull;
2011 Trinity Composites Matrix "Pro" Carbon hull, -2"
Trinity Footholds
Dual Thrust Scuppers mounted in the pump area, (Currently Plugged)
ATP Performance Waterbox
Stock Fuel tank with Wamiltons Billet Internal fill
Thrust Innovations Billet External Fill
Engine and electrics;
X-Scream SS846 Billet cylinder kit (anodized black) (195 psi)
OEM Trued and Welded crank
64U Cases ported and epoxied by X-Scream
Boyesen/Full Spectrum Extreme Velocity Intake
Dual Mikuni 46's modded by X-Scream and painted black
B-Pipe modded by X-Scream, (limited chamber) and ceramic coated by Airborne Coatings in Denver, NC
Prok Filters with Outwears
JSS 62T Stator with JSS Stainless Laser cut washers
JSS Coil
TBM Lightweight Charging Flywheel
Cold Fusion Billet Flywheel cover
Billet UMI lightweight couplers
ATP E.P.I.C. programmable ignition Module
Deka ETX-12 AGM battery
Custom aluminum mini Battery box
GP800 Motor Mounts with Kenney Keepers
Pump and handling;
144mm Solas Stainless Pump
144mm Solas Stainless Wear Ring
Skat 13/18 Swirl Impeller
Worx 201 Intake Grate
Stock D-cut Rideplate
Steering and handpole;
RRP Handpole with black annodized tubes
RRP Dual breather bracket
RRP Chinpad support bracket
RRP Pole Spring mount
Stock modded pole spring
ADA Sealed bearing steering system
X-Metal -2.5" Turnplate
X_Metal Straightbars
Wamiltons RRP Chinpad
JSS Start/Stop switch
ODI Grips
Sato Finger throttle
Kawi HD 650sx Throttle cable
Hot Products Adjustable Throttle Drum
Asking $18K ,OBO , located in Savannah GA area.
Clean GA title in hand
Hull;
Trinity Footholds
JSS Coil
Pump and handling;
ODI Grips
