2008 Yamaha Superjet
DC
Price: $6750
Shipping: NO
Trades: NO
Selling my wife’s Superjet. We no longer ride much and I sold mine so we are looking to sell this one as well. Starts every time and runs perfect. Water ready and clean title ready to go.
Engine/Electronics/Fuel
  • 701 62T Engine
  • Blowsion Bilge Bracket & Single Rule Bilge w/ Bar Mount Switch
  • Rad Dudes Exhaust Tube
  • Lightened Flywheel
  • Rebuilt Carbs w/ Mikuni Kits + T-Handles
  • Rhaas Motor Mounts
Hull/Pole/Steering
  • 2008 SuperJet Hull Professionally Painted w/ 2015 Graphics
  • Wamilton Rickter Footholds
  • TomSki Front Foothold
  • HydroTurf Molded Diamond w/ HydroTurf Padding
  • UMI Steering Plate
  • Blowsion Fat Bar Clamp
  • RRP Straight Fat Bars w/ ODI Grips
  • Blowsion Billet Throttle Lever
  • Blowsion Pole Spring
  • Blowsion Billet Gas Cap
  • Blowsion Billet Fuel Filler Neck
  • Blowsion Billet Bow Eyes
  • Blowsion Billet Kick Plate
  • Blowsion Carbon Fiber D-Cut Ride Plate
Price: $17k
Shipping: NO
Trades: NO
Up for sale are my 2008 and 2006 Superjets. My wife and I just don't ride them as much anymore and I finally decided to let them go. I have owned these skis for many years and put a lot of time and money into getting them to where they are now. Both skis are ready to hit the water and always start with one push of the green button. They have been ridden in brack-ish water in Southern Maryland and flushed/washed every time. I will NOT ship them and I will not separate them unless the trailer is sold first. Both skis are titled legit as Superjet's with matching HIN's and registered in Maryland. The trailer also has a title but it is not registered. I will water test with cash ONLY in hand. No BS, no stories, no gimmicks - ready to hook up to your vehicle and drive straight to the water. I have taken extremely good care of my skis and the pictures will show just that.
2006 Yamaha Superjet (Black/Green)2008 Yamaha Superjet (Black/White)
  • 701 62T Engine
  • New OEM Crank/Pistons/Seals/Gaskets Fresh Bore 0.5mm (7/24/2021)
  • ATP v2 Girdled Head (180 PSI front / 180 PSI rear)
  • Factory B-Pipe w/ Dual Cooling
  • JM Waterbox
  • Blowsion Flow Control Valve
  • OEM 62T CDI w/ Rev Limit Mod
  • OEM Rebuilt Coil w/ MSD Boots/Terminals
  • OEM PFM Lightened Flywheel
  • OCD Solutions Surf Armor Battery Cables
  • OCD Solutions Tidy Dual Bilge
  • Rebuilt/Jetted Mikuni 38 Carburators w/ T-Handles & Billet Throttle Wheel
  • Cold Fusion Gas Tank (Internal Fill)
  • Blowsion Dual Bilge Bracket & Dual Rule Bilges w/ Toggle Switch
  • Blowsion Engine Keepers
  • 2020 OEM Superjet Engine Mounts
Hull/Pole/Steering
  • 2006 SuperJet Hull w/ 2007 Custom Graphics
  • Defoamed Hull & Replaced w/ Closed-Cell EVP Foam
  • Trim Tube, Dual Cooling Tube, Stock Siphon Tube, Hull Drains
  • Hurricane Industries Wide Tray
  • Custom Aluminum Foothold Plates/Brackets
  • RRP Ninja Footholds
  • Dakine Footstrap
  • OEM Hood Repainted
  • Billet Bow Eyes & Flip Up Bow Eye Loop
  • Hydro Turf Molded Diamond & Two-Tone w/ Hydro Turf Padding
  • ATP Handle Pole Bracket w/ Spring Perch
  • Blowsion Handle Pole Spring
  • ATP v2 Adjustable Billet Handle Pole w/ Shock Pad
  • ATP Chin Pad
  • ATP Mini Steering System
  • ATP Solid Riser Bars w/ ODI Grips
  • FRI Pole Limiting Rope
  • Blowsion Gas Cap Delete
  • Blowsion Recessed Dash Panel (Primer & Bilge)
  • Blowsion Heavy Duty Steering Cable w/ Rhass No-Slop Cable Ends
  • Wamiltons Billet Throttle Lever
  • Thrust Low Profile Billet Water Bypass/Pissers
  • Thrust Low Profile Billet Bilge Outlets
Pump/Trim
  • Solas 12-Vein Stainless Mag Pump (Rebuilt 7/29/21)
  • SNL Industries Drive Shaft (New 7/29/21)
  • 2008 SuperJet Prop
  • X-Metal Trim System
  • Worx 228 Intake Grate
  • RRP Carbon Fiber Ride Plate
  • Stock Bilge Siphon, Dual Cooling
  • 701 62T Engine
Hull/Pole/Steering
Still for sale
