Located in Sarasota, FL. Needs nothing, is 100% turn key ready to ride and is titled. $2500 shipped in the US to the nearest freight hub.
1990 Yamasaki 701sx
-90 SX Hull + pump
-Rhaas swap plates
-Fresh built Yamaha 701 - appx 4 hours on new engine
-stock 61x bottom end with 62t top end and milled head. Fresh bore at .5mm over. All new seals, gaskets, etc.
-Factory pipe exhaust manifold, kawi 650 dry mod cheater pipe
-Bad bones in-line dual resonator
-PJS big tank
-wetjet intake mani / SBN46 carb with throttle drum and Tau Ceti f/a
-ocean pro finned rideplate and pump nozzle
-pjs intake grate
-skat trak straight pitch 19 degree prop
-new battery, fuel lines, cooling lines
-4 degree bars
-bilge
Was given a full cosmetic detail today, buff/cut and polish, wax and ceramic coat.
1990 Yamasaki 701sx
-90 SX Hull + pump
-Rhaas swap plates
-PJS big tank
-pjs intake grate
-4 degree bars
-bilge
