Mike W
Infidel
- North Florida
yeah, i got my posts mixed up...
Mike, ur build is looking good... keep up the killer work.
Thanks. It is a PITA but worth it in the end.
what did you foam every thing with ??
is is the 2 part or the canned beans junk??
can you use the canned stuff also??
I used 3lb 2 part foam from US Composites. Even the 3lb stuff is strong. If you use a drill with a wire brush it makes it easy to shape the foam.
Also before I layed the glass over the foam I mixed up a little 404 filler and put a thin layer on top of the foam to help the glass stick to the foam. I'm sure it added strength as well.
