- Sarasota, FL
02' SuperJet
$4800
Located in Sarasota FL
Selling cause' I bought an 1100 SXR that's more my style.
62t/61x 701, dual 38's, stock intake
Factory Pipe B pipe
ADA Girdled head with 33cc domes (180 psi, 93 pump gas)
Jet Maniac YamaSaki coil w msd wires
CT Carbon Reeds
New agm batt (3 months)
New OEM solenoid
Hooker 9/15 prop
Worx 201 Intake Grate
Jet Dynamics Extended Rideplate
Extra spare stock rideplate D-cut
Worx Pump Shoe (sealed)
Solas 144 SS wear-ring housing
ProTec Stubbie Cone
Tubbies
Scupper (currently blocked off w removable plug)
Rule Bilge (single, works!)
Flush installed, used every ride
AC Racing -4" Aluminum pole w custom removable bracket to stock -1 length (1/2 aluminum polished bracket), pole can be -1" or -4"
Billet lowered pole bracket
Delrin pole bushings
Lowered hood with handholds Blowsion Joe Kenny Hood.
Lowered nose piece (not yet mounted)
Billet hood hooks
Blowsion quick steer (w extra needle bearings)
Riser straight bars with ODI grips
Billet finger throttle
24/7 Footholds
26mm underpadding
Hull has trim tube and 2nd cooling line installed (currently single cooling)
Diamond hydroturf (2016)
Corvette Laguna Blue paint [2016)
Ski is clean, runs strong, snappy low end, rips, and has been cared for well. Lots of fun to ride, very versatile.
Only potential issue is bendix occasionally sticks (doesn't throw sometimes).
Will ship on your dime.
Pm for details and more pics. Local test rides available if you have cash.
Sent from my SM-G960U using Tapatalk
$4800
Factory Pipe B pipe
CT Carbon Reeds
New OEM solenoid
Hooker 9/15 prop
ProTec Stubbie Cone
Tubbies
Billet hood hooks
24/7 Footholds
26mm underpadding
