Best pump for 2023 Yamaha Superjet
an acquaintance bought one of these last year. Same TAPERED! he had to fix it. Hard to believe a company as big as solas is still machining with something that is flexing and tapering the bore. I've heard they can still be an issue on the superjets too! if buying new get one from John fixed
IceRocket1286
Metro Detroit
Figure I would provide an update. After sending the pump back to Blowsion/Solas looks like the pump is defective due to a design issue. I guess since it was so fresh to market I was one of lucky few to test it out early. Have the stock pump in now but if Solas ends up fixing the issue at some point I would def get it again. Worked great for the short time I had it.
On a side note - just added Viper cam with ECU tune and pump wedge. Def worth adding if you have pretty much all the other upgrades....
How do you like this setup? Which ECU tune? I'd like to try the pump wedge...but point the nose of the ski down for better drive/hookup. I'd try it in the up position as well.
