SX/SXi/SXi Pro jetting twin 46 mukunis
Hoping someone could help me out- trying to jet my twin 46mm mukuni's they are RIVA modified (i think) anyway the jetting is way out was on a crazy fast raceboat.
Twin 46 mukunis on R&D manifold
Fresh 779cc with full porting (exhaust and inlet) 2mm over
Comp is currently at 195 (but might bring that down to the 180ish) its a lee's head
V-force reeds with spacers
factory pipe with sxr chamber (front exit no waterbox)
lightned flywheel- 650 electrics
Use for the boat is all freeride- dont get it on WOT to much-
what are the symptoms? and current jetting? if the ski stalls your lean, if it blubbers your fat? if it helps any with dual 44's i had jetting at 115L 155H! should give you a better starting point!
was in a raceboat with a dry pipe etc.. its as rich as hell- the jets have been drilled out, it runs on the lows and highs fully shut and the high is still to fat.
I run K&N filters with socks , 120/115 jets 2.0 needle seats, and dull silver springs - gives 26psi pop off
very similar spec engine/ ski to yours - hits pretty good, should give you a start point if mothing else
(superjet BTW)
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Are these RIVA Powerbomb carbs? You say modified by RIVA, what does that exactly mean? Taper bored? Returns bleeds drilled out?
The spec's I sent you are for standard aftermarket Mikuni's.
yeh they are Taper bored.. Not sure if returns are drilled out, cannont bold up a standard filter only a torsetti or something..
I would assume they are powerbombs-- Just bought them of an x race ski..
jet them different?
Take the fuel pump blocks off the carbs and see if there is a very small hole or a big hole in the return passage.
Well did all the riva have returned drilled and why would you want the returnes drilled out?? I put a jet in the R-line to restrict it a bit-- Is the powerBOMB a 46 or 48?, how do i know thats what i have?? ? havent toyd much with jetski carbs..
A Powerbomb is a 48 carb.
Some aftermarket carb makes drill out the return restriction so that the fuel pressure can be fine-tuned by replaceable jets in the return line.
I put a jet in the line to restrict the returned a bit
What size jet did you put in?
Depends on the carbs. I used to use a #60 main jet for a Powerbomb and also for older 48 Full Spectrums.
You need to find out 1) if they are internally restricted, and 2) what the size of the restrictor is.
Or c... findout what jet they guy had in the raceboat?? I assume id run the same? right? cause he deff had one in there..
thanks fr your help MATT.. hopfully ill be able to sort these suckers out!
