750 sx on ebay....funny
ger87410
How did I get here?
Fort Worth
A 14 gallon gas tank?? Did I read that right?
KAWASAKI 750sx SPECS:
Engine type: 2-stroke, 3-cylinder with crankcase reed valve induction
Displacement: 1,071cc
Horsepower: 120 at 6,750 rpm
Bore x Stroke: 80.0 x 71.0mm
Compression ratio: 5.8:1
Cooling system: Inducted water
Carburetion: Triple CDCV 38s with single fuel pump
Lubrication: Superlube Oil Injection
Ignition: Digital CDI
Starting: Electric
Propulsion system: Jet pump, axial flow, single stage
Thrust: 803 lbs
Fuel capacity: 13.7 gal w/1.8 gal reserve
Oil tank capacity: 4.0 qt
Overall length: 108.7"
Overall width: 42.1"
Overall height: 39.3"
Dry weight: 589 lbs
Color: Sunburst Yellow/Jet White
It says the length is a little greater then 9 feet and the width is darned near 4 feet. Are we sure those a specs for a 750sx?
ger87410
How did I get here?
Fort Worth
He cut and pasted the wrong table. Would be cool to get an 1100 SX triple though!
That's what I thought. Expect him to change the post as I sent him a message saying the info was off.
Either he'll change it or he's trying to diggle someone. Don't get diggled!!!
