- pittsburg
hi, i just purchased a 1990 650 superjet w/worx intake grate n ride plate and freestyle cone. what other mods can i do for some more bottom/mid power. is a dual carb set up a good idea?
Exhaust and higher compression head (180-ish?) for sure. Also, if it's the stock impeller, replace it. Don't worry about a dual carb setup.
When thinking about mods, also think about ones that could still be used if you decide to swap out the engine for a 701...such as the exhaust.
