First off here is what I am working with.
62t/61x cyl. and cases ported by ProTec
82mm bore
ProTec Cast Head
5mm stroker crank
dual 44's no chokes w/Riva Fa's
Riva Pipe Not sure which one but the manifold is red and waterbox
Stock ignition with lightened flywheel
Ok, I got it sealed up yesterday and did a compression check. Because on ProTec's site it said that the head used with the stroker crank would require race gas. Anyhow I whirled it over on the bench and got 200 psi. in both holes and .054" squish. Now I'm guessing that I'm past the limit of pump gas? If I am can I just add another base gasket to lower it a bit? I would think it would be good for .015-.020". And if not what are my options?
82mm bore
ProTec Cast Head
5mm stroker crank
