Jetting for a filled in crossover
n247hp
N247hp
Philly
Hey guys.
I recently filled in the crossover on the stock intake of my SJ. I am pretty sure i have the wamilton jetting kit right now and cant really find the right tunning point. Any suggestions. Before i had the crossover filled in, i ran the low speed screws at 1 turn out and it felt great, but now it just gets loaded up and doesnt have the same snap. I tried to go up from 1 turn out and no help and i tried to go less than 1 turn out and didnt really help much either but didnt want to lean it out.
Please help!!! I suck at tunning carbs. thank you
SUPERTUNE
Race Gas Rules
Clearwater Fl.
What engine setup recipe are you following? Why did you fill it in?
When you do fill in a crossover, the signal is a lot stronger to the carb and you DO need to lean the jetting down if you want it to work...just do what the engine is telling you to do.
n247hp
N247hp
Philly
thanks guys just ordered one. so what RPM range should i expect from a stock stroke 701 with a 82 bore a 31cc head and a B pipe on stock 38s?
n247hp
N247hp
Philly
When you do fill in a crossover, the signal is a lot stronger to the carb and you DO need to lean the jetting down if you want it to work...just do want the engine is telling you to do.
I filled it cause i read that it gives better response. Plus i see that all after market intakes don't have a crossover so i figured it would work better. I was scared to lean out too much not to hurt the engine. I figured if i nearly have to close the low speeds i should probably re-jet right?
