OEM Fuel & Vent Line
Shifty
- SuperJet Thursday -
I need to plumb up my new carbs and will not have enough OEM line to do this. I really do not want to go with the clear colored stuff for my fuel. When I removed my water seperator, I was left with a few feet of "Vent" tube. Is this stuff the same as the OEM fuel line? It is of a different color and seems more plyable. I need some to run my pulse lines too and don't wan't them collapsing under vacuum.
I may have answered my own question but I would really like to stick with OEM line here.
Also, does anyone know where to get those stainless Tee's that have the swept leg? (check the pic)
Thanks
2lick
Brap!!!
Limerick, PA
I bought a bunch off eBay a year or two ago.....
They are made for soft drink machines or something.... I think.... Good luck!
I think #.0 did as well try looking for some of his posts.
Mark44
Katie's Boss
100% one place
The two line types are different I would just order up 3/16 ID tygon from McMaster Carr. I think #0 found that fitting in McMaster I would PM him.
Mark44
Shifty
I found his post again and PM'd him. I did remember seeing them at McMaster but they were like $20.00 a pop on their site. I bought some of the anodized alloy tee's from McMaster but the .170 seems way too small for the lines. I should have bought the 1/4" ones.
Shifty
Thanks, I just got it from #0. The only thing is link you listed is for 3/8" and is in stock, the 1/4" are "Sold Out".
I don't know what to do, I like the anodized ones I bought from McMaster but they seem really loose in the OEM line and the ID seems tiny. I am afraid if I trade them out for the 1/4 they will be too big.
QuickMick
API 1104 AWS CWI
ok, you didnt state what size you needed. but they sell both sizes.
I ordered a whole bunch different sizes and if I have a 1/4" one I will let you know and mail you one. If I forget please PM me. I get busy working on my house after work.
Mark44
Katie's Boss
100% one place
Measure your ID of the OEM fuel line, it is smaller than a 1/4". 3/16" fuel line fits the carbs much better than 1/4"
The 3/16 tygon will go over the 1/4 barb also.
Mark44
Shifty
Sorry about not stating the size needed. I will see what going on tonight. I just finished intalling my cylinder, head, manifolds, etc and will have the motor back in the hull after I 5200 the bulkhead. Once I get the engine in I will see how much line I have to work with and if my aluminium Tee's will work. Thanks for the offers, I will let you guys know tomorrow.
Shifty
Alright, I was test fitting the McMaster Carr Tee with the stretched end of the OEM line. It was alreadly enlarged by the carb nipple. The Tee fits alright when inserted in a fresh cut portion. If I went up to a 1/4" Tee it would be a real pain to remove. I will run these and scrounge up some crusty OEM line since I used my slack return line to run new pulse lines.
