- Nova Scotia, Canada
I am rebuilding a 1990 SuperJet that has been sitting in a garage for 4 years.
I am a newbie for sure so I thought a cheap, 20 year old ski would be a good one to try to fix up. If I screw up big time, it won't break me.
I pulled the motor out and found that the shaft that goes from the coupler into the rear part of the hull is seized completely solid.
Not only that, when I removed the 3 bolts, it will not come off.
Any suggestion as to how to get this thing off? I'll set up a web server on my computer and post a link to a video that shows just how stuck it is - using a 4-foot piece of wood as a lever, I pulled as hard as I could with one hand (recording with the other hand). It looked like the wood was going to break.
http://24.138.26.27/stuck.avi
I'm not sure what's behind that shaft, so I'm not sure which way to pry on it.
Would a shot of Loosen-All (or whatever its called) help?
Any suggestions?
Any suggestions?
