I have just purchased a Jetinetics flywheel, and I want to set the timing at idle so that I don't melt my pistons. I have never checked the timing on a two stroke before, so I don't even know if my timing light will work as expected.
Equipment: I have a nice snap-on timing light with a digital rpm readout, and I can also put a set timing advance in it.
Process: I plan on finding TDC. Do I find it in the front or rear cylinder, or doesn't it matter?
After finding tdc, I will make a mark on my flywheel, and cases that line up.
Next I will set my timing light at the desired advance for idle.
I will start the engine, and observe how far off the marks are, and which way the stator should be moved.
I think this sounds right, but I could be very wrong. I would like to hear your input on this process. Also what is the stock advance at a certain RPM?
I also tried calling Jetinetics, but they weren't in.
