- Santa Barbara, CA
I recently blew a coupler to the point where the b pipe was disconnected from headpipe, and the water was flowing straight into the hull from the headpipe. Oddly enough, the ski still ran with this condition (albeit a small decrease in performance all around) just with a much louder sound than usual (which is what gave me the indication that something was not connected properly). I have a front exhaust connection.
Ordered a new coupler, and my mid to top speed is pretty much completely gone and my bottom end power ranges from 30-50% of what it used to be.
I then noticed that the elbow between the b pipe and the water box was leaking exhaust into the hull along with water.
I fixed that and the performance hardly increased at all, boat will barely plane off, and will reach about 30mph with the throttle pegged.
I then replaced the plugs, which had zero effect.
Things I have done to fix the problem:
Adjusted high speed screws (did change the attitude of the engine)
Adjusted low speed screws (did change the idle of the engine)
Adjusted the top water screw on the pipe (no change in performance)
I am going to hook up with a friend tomorrow and start tearing it down. First thing I am going to check is compression.
Anyone have any suggestions? Would riding basically without a coupler on my pipe ruin anything specifically?
Specs of the ski are in my signature.
