to access ya router, type your IP into the internet address bar
brings up router settings, etc
not *your ip, but your *gateway ip (your router is your gateway), generally speaking it will be whatever your computers IP address, but with a .1 at the last octet instead of whatever ip comes up for your dhcp lease.
easy way to get your ip address:
start->run->cmd.exe->ipconfig
Line you're looking for should start with "IP Address:"
you could also find out specifically which ip address is your gateway/router ip by just doing a "route print" in your dos window. look for the line that has the network and destination address as 0.0.0.0. its typically in the first few lines or the last few lines, depends on your o/s.
:crazy:
