- Tri-Cities, WA
So I bought this 550 from a guy who had bought it from another guy and it hadn't touched water since 04'. I figured for the $100 I was spending, I could stand to make a little profit considering I had a ton of spare aftermarket parts laying around. The ski is totally stock and was missing a starter. I pulled the engine today so I can run a compression test and put in a starter. Right away I noticed this little black bulb thing attached to the same bracket as the fuel separator bowl. One fuel line from goes in from the on/reserve valve and a small primer like fuel line goes out into the carb. There's also wires that go into it from the carb side of the e-box. I can't seem to get the pics to upload because the file is too large. What I'm wondering is if I can disconnect this. I'm sure that I can, I'm not sure what I'm supposed to do with the wires though. I know I can get rid of the separator bowl and just use an inline filter but I want to make sure I don't ruin anything by leaving the wires unattached.
I'm also wondering if there's supposed to be a gasket between the starter flange and the flange it bolts to off the bottom case.
Thanks for all the help
