accbr
addicted
- Lexington, KY
buy BLACKJACK'S from JETWORKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
So I can pull them out, and press them back in at a different angle? What type of glue?
no, go back to stock and send me your carbs. :439:buy BLACKJACK'S from JETWORKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
do you always do work on black velvet or is that just for the photo shoot?![]()
I'm doing all my portraits on that stuff now.
Should I go back to using the formica counter top?
Use the big slide hammer because it takes quite a bit of force to get these things out.
If you're doing a single carb installation you can use the straight primmer fittings part number 62T-14251-10
I just went and removed a few fittings from some new 46's getting converted to 48's and here's a couple pics.
I like it, let me know if you need a hand model.
I was getting ready to put my Full Spec on my motor, and noticed the fuel fittings are probably going to hit my filter. Do these press in or screw in? I'd like to have them both point toward the pump side.
