Shifty
- SuperJet Thursday -
- Austin Texas - Lake LBJ
I have my turf in for my ski and am about to tear up the stock crap. I think I will only be doing the bottom section this time. I want to add foot holds at some point, but I will wait untill winter for that when I can take my time. I have a few questions before I begin...
How to you terminate the turf at the rear of the ski? I will be using the 25mm underpad all the way to the rear bondline. I will then go over that with some cut diomond turf. Do I cut the underpad flush with the end and just wrap the turf around and trim to a knife edge, or should I continue the turf up under the bondline?
Seems like it would come unglued easily with landings. What about prep? I have read to sand the turf before installation. But I am not crazy about sanding my new hull down untill I get uderway with the footholds. Will the adheasion be enough between the bare tray and turf if left glossy?
How do you sand this underpad? I plan to rertain the stock corner caps at the rear and need to taper this thick underpadding down. I tried a belt sander with 80 grit and it is slow. Seems like a flap wheel on an angle grinder would do a better job, whats the best method?
Any advice is much appreciated,
